26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Back Lit Sign
I am working in Revit 2009. I am trying to create a solid sign with a backlight (probably from rope lights). What is the best way to create this and render it? I have tried to set a solid to self luminance but that just makes that object glow and it isnt bright enough
I created backlit signs by having two different materials in the sign face. Each one has a different transparency setting if you place lights behind it. Otherwise set each material to a different level of self luminousity. These were lettered signs. I imported cad lettering to get the linework. Once you have the letter sketch for the letters, you use the same sketch to cut the background.
ADA Sign - Text not showing |
Tue, Sep 24, 2019 at 4:03:48 PM
Parametric Exit Sign |
Mon, Apr 14, 2014 at 12:38:11 PM
13
Signage |
Tue, May 30, 2006 at 2:22:58 PM
MODEL TEXT BACKWARDS |
Mon, Feb 25, 2013 at 1:50:57 PM
Text On A Retail Sign |
Fri, May 6, 2005 at 3:21:58 AM
