25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> area plans again?
Hi, So what is the easiest way to subtract the area that my columns take up in an area plan. i could draw area boundraies around each column which isn't so bad, but if i delete a column then the area boundry stays. any ideas anyone? using revit building 2009 thanks
86 Posts No Rating |
Hi all,
old topic, maybe some new solutions in 2011? I also need to be able to create area plans in which bearing walls are ignored. So no area over a bearing wall.
Any ideas? Thanks!
Are you talking area plans really or could you use rooms?
Area plans can be sketched instead of letting Revit create them, then just point to the lines to sketch and exclude your walls.
Hi WWhub,
no I really want to use rooms. The option to sketch the lines by hand is fairly good. I've been doing a test-project, and it works fine. I was searching for the even easier way, but this is also good.
I think we're gonna use Rooms in the earlier stages of a project, and when making the drawings for the building-permit, add area-plans. Rooms so we can tag the rooms in an early stage, without the need of creating seperate plans, and areas to be more flexible in determing the boundaries.
Is there a way, to make an area take over the name of the room?
Thanks!
Under the room & Area pulldown, you have some options. Just set these the way you want for your room areas. See attached:
new Area Scheme question |
Tue, Jun 20, 2017 at 4:11:49 PM
Using Area Plans as Main Floor and Unit Layout plans |
Mon, Mar 29, 2021 at 1:59:33 PM
Area Plans for design options |
Fri, Jul 21, 2017 at 1:37:36 PM
Area Plans |
Wed, Nov 1, 2006 at 10:03:12 AM
Stairs and Area Plans... |
Thu, Nov 29, 2007 at 4:40:40 PM
