22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Bearing walls solid fill
8 Posts No Rating |
How would I make ONLY my bearing walls show up as a solid? I am using medium and fine detail levels for my structural framing members, so the course fill pattern does not apply.
I don't believe this is possible.
You can choose to only show structural walls and then use your materials settings to show them all as solid. (do this by setting your view to structural discipline).
You could also show parts of a wall that are not structural with a dashed line type or not at all using override host layers and setting finish layers to a different line style...
But no i don't think you can set your structural walls to show as solid and your non-structural walls to show not filled. Its all structural and no non-bearing or all walls with line type differences for non core components of the wall.
HTH.
The only way I can think of would be to give each structural wall type a "course fill pattern" of solid. This would require that you adjust this setting for each type of structural wall you have in the project manually. Might be an OK solution if you don't have a ton of wall types.
HTH
Tom
Showing Load Bearing Walls from a lower Floor Plan |
Thu, Feb 16, 2012 at 10:02:04 PM
Load Bearing Walls hatched |
Tue, Apr 13, 2010 at 7:18:55 AM
Revit Arch. 2009 - Floor Plan Solid Fill blocks out walls |
Mon, Mar 30, 2009 at 2:22:09 PM
Solid Drafting fill pattern |
Tue, Jun 23, 2015 at 1:35:01 PM
Solid Fill Pattern |
Wed, Jan 9, 2008 at 1:55:24 AM
