Forums >> Revit Structure >> Technical Support >> Exporting Half a Model To RAM
Wed, Nov 19, 2008 at 1:35:47 PM | Exporting Half a Model To RAM
PennState
I have a Revit Model that is broken up into two seperate buildings. I was wondering if I am able to export just one of the buildings into RAM?
Tue, Dec 9, 2008 at 4:12:24 PM | Exporting Half a Model To RAM
PennState
I discovered that you can export one of the buildings into RAM at a time. It is done by listing each building as a seperate selection set. This can be done through the edit menue. Then when you go to export the model, just check off the box that says Export Current Selection Only.
model too slow/dragging when exporting
Wed, Jan 18, 2006 at 9:54:44 AM
Ram Structure imports
Thu, May 31, 2007 at 1:17:14 PM
Importing Ram Model
Thu, Feb 28, 2008 at 9:08:34 AM
Exporting REVIT 8 Model to Photoshop7
Wed, May 18, 2005 at 11:50:04 PM
Revit model half shaded half wireframe
Mon, Dec 2, 2013 at 11:30:03 PM
Page generation time: 0.5485
