Forums >> Revit Structure >> Tips & Tricks >> Elevation Levels Q's
Wed, Nov 19, 2008 at 1:29:44 PM | Elevation Levels Q's
arch04
My question is, when you create a 3d object then review the object in elevation you have Elevation markers.  These markers you can revise by assigning different heights and names.  The question is, instead of having a numerical value for a height (say 20'-6"Winking could you have it read "varies" ?
 Thanks.
REVIT 9.0
Sat, Nov 22, 2008 at 1:37:20 PM | Elevation Levels Q's
4 Stars: 205 Votes
No, every "Elevation markers" represent that (elevation), so, in one elevation marker you don't have "Varies" elevations...
Sun, Nov 23, 2008 at 12:16:36 PM | Elevation Levels Q's
erland73
erland73 Avatar
4.5 Stars: 85 Votes
arch04, the only way you can do that is turning off that elevation marker and creating an annotation family similar to an elevation marker to "simulate" the level symbol adding the text  "varies" that you want.
Elevation Levels Mess
Thu, Jun 26, 2008 at 11:53:13 AM
Wall won't show in North elevation
Thu, Oct 9, 2014 at 12:21:15 PM
Cannot see my floor levels
Tue, Mar 10, 2015 at 12:42:26 PM
Levels are missing - I tried all solutions on forums no result
Wed, Jan 30, 2013 at 10:57:43 AM
Adding 100' to Spot Elevation
Tue, Jan 31, 2012 at 10:36:28 AM
Page generation time: 0.5257
