Forums >> Revit Building >> Technical Support >> LOST DIMS AFTER EXPORT TO ACAD
Tue, Nov 18, 2008 at 11:32:03 AM | LOST DIMS AFTER EXPORT TO ACAD
rquist
EXPORT DRAWING  FILE TO ACAD.
SECOND FLOOR PLAN RETAINED THE BUILDING DIMENSIONS.
FIRST FLOOR PLAN DID NOT RETAIN BUILDING DIMENSIONS.
LOOKED BACK IN REVIT FILE AND THE DIMENSIONS ARE THERE, DON'T SEE ANYTHING IN VIEW PROPERTIES THAT LEADS ME TO ANY CONCLUSIONS.
ANY THOUGHTS?
Tue, Nov 18, 2008 at 11:37:50 PM | LOST DIMS AFTER EXPORT TO ACAD
sharath
might be some bugs try exporting again.always there will be some problem if you export to cad either dimention or scale or minor problms.try scaling it.
Revit 2010 - Export to ACAD 2008 .dwg?
Wed, May 6, 2009 at 2:07:20 PM
ACAD export filled region
Tue, Aug 4, 2009 at 7:09:16 AM
leader export to ACAD problem
Tue, Aug 4, 2009 at 7:05:49 AM
Text Export to Acad
Fri, Jan 12, 2007 at 2:32:11 PM
RAC2008 EXPORT TO ACAD: C SIZE TBLOCK CONVERTS TO LARGER SIZE IN ACAD
Thu, Aug 7, 2008 at 11:00:14 AM
Page generation time: 0.1354
