Forums >> Revit Building >> Technical Support >> Object Permissions
Tue, Nov 18, 2008 at 10:13:51 AM | Object Permissions
psemrau
We are working a project with our branch office, we are using the same central file and it hasn't been easy.  Sometimes they own objects they seem unable to relinquish (Don't know why, inexperience might be the answer).
Anyway, this is not about their revit skills, so back to my question.
Is there a way to "kick them out" of the central file?  That is, relinquish their stuff remotely, without even bothering to ask them to do it.
I noticed in the revit commands TXT file the is a: "Debug-Worksets-Kill Borrowings and Requests" command, will this do the trick?
Wed, Nov 19, 2008 at 9:47:43 AM | Object Permissions
If both offices are using the same model, you need to work out how you can do this.  Just kicking them out will in effect throw away their work.  I think you need to read up in the help using remote as your search.
Working Off-site and Off-line
Multiple Members Logging in Remotely
Wed, Nov 19, 2008 at 11:04:37 AM | Object Permissions
When someone owns something and you MUST have it released, open a REVIT session, goto settings and change your user name to the party that owns the element.  Open the central file, save to central relinqishing all mine, close the file w/o saving.  Now at a blank screen, change your user name back to your own and open your local file.
Wed, Nov 19, 2008 at 11:07:44 AM | Object Permissions
psemrau
THANKS!
Can't Save Changes
Wed, Mar 25, 2009 at 5:03:26 PM
User Permissions for Revit Files
Wed, Jan 3, 2007 at 4:02:13 PM
The resistance of Revit
Fri, Jun 3, 2016 at 10:01:01 AM
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Object parameters
Mon, Jul 28, 2008 at 12:53:06 PM
Page generation time: 0.4059
