Forums >> Revit Building >> Technical Support >> Window Family with Muntins
Mon, Nov 17, 2008 at 9:25:54 PM | Window Family with Muntins
CarriageStone
3 Stars: 2 Votes
I would like to have a window family that would allow for the following parameters:
  • Width & height
  • Casing option (interior & exterior)
  • Muntin options including the number of lites ( # wide x # high), per sash, and the muntin width.
Any idea how to create this?
Also, attached is a profile I created for an exterior casing that we use for dormers.  Any suggestions how to create a sweep that could be applied to this window family?
THanks all!
Tue, Nov 18, 2008 at 2:54:56 AM | Window Family with Muntins
Dafpfy
3.5 Stars: 11 Votes
Height and width is best defined with Ref planes and a dimension you then label with a parameter,
casing i would load in a generic model of the casing created with solid sweeps or extrusions ,with all the parameters you need ( check out F1 for nested families)
for the last part is my english not good enough to understand, but i can say you can alling an array to ref planes and ad a parameter ( integer ) to the array to control the number of arrays .
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, May 8, 2015 at 11:31:18 AM | Window Family with Muntins
ramirezo
I'm basically having the same poblem (Muntin Options) where I dont just know what to do, start. I've been reading about arraying family, nesting families and what not, but haven't found a clear step-by-step guide on doing so. Can anyone help me?
I basically need to re-create these options, just dont know how to start.
Fri, May 8, 2015 at 11:43:22 AM | Window Family with Muntins
ramirezo
Edit: Deleted repost
Edited on: Fri, May 8, 2015 at 11:44:11 AM
Edited on: Fri, May 8, 2015 at 1:18:51 PM
Fri, May 8, 2015 at 12:55:44 PM | Window Family with Muntins
I think I would start with one of the pella windows on seek.
Fri, May 8, 2015 at 1:20:56 PM | Window Family with Muntins
ramirezo
you can't interchange muntins in the Pella window
Fri, May 8, 2015 at 1:28:49 PM | Window Family with Muntins
ramirezo
Fri, May 8, 2015 at 1:29:47 PM | Window Family with Muntins
What do you mean by 'interchange'?
The number of the muttins can be changed - both horizontal and vertical.
Rework their formulas.
Edited on: Fri, May 8, 2015 at 1:34:36 PM
Fri, May 8, 2015 at 1:33:03 PM | Window Family with Muntins
ramirezo
I download it, and the vertical and horizontal mullions under "Other" are all greyed out. I only have the option between Traditional Grille and Prairie Grille. There are also no options under the Edit Type.
Fri, May 8, 2015 at 1:36:20 PM | Window Family with Muntins
Edit the family and take out the formulas for the numer of muttins.
Residential Window Muntins
Fri, Apr 5, 2024 at 7:57:34 PM
Window Muntins
Wed, Dec 17, 2003 at 8:38:36 PM
Need a little help with understanding families
Tue, Jun 24, 2008 at 3:46:20 AM
instance of window not cutting anything
Fri, Jul 13, 2007 at 12:05:31 PM
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:06 PM
Page generation time: 4.8370
