Forums >> Revit Building >> Technical Support >> Door family parameter problem
Mon, May 16, 2005 at 4:26:19 PM | Door family parameter problem
Bastian
I'm trying to make a new door family which is a double flush door. Thing is that I'm not getting it that well done... When I try to change its width it all gets messy (see attached pic). What am I doing wrong and how do I correct it?
Mon, May 16, 2005 at 4:27:02 PM | RE: Door family parameter problem
Bastian
ops, I posted the family first... here's the image.
Tue, May 17, 2005 at 12:50:01 AM | RE: Door family parameter problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The symbolic lines you are using to define the swing aren't associated with anything. Constrain them by adding a parameter that will show the correct leaf size. Also you don't appear to have a left/right origin location. Select the centre left/right reference plane and set it to define origin. 2D elements need to be defined the same as 3D elements. HTH.
Tue, May 17, 2005 at 7:18:43 AM | RE: Door family parameter problem
Bastian
I made so many changes to this and so many saves that by the time I posted this I knew that there were things missing. No wonder it worked so badly. Thanks Mr.Spot Smile
3D Swing parameter!! Help!!
Sat, May 11, 2013 at 7:03:34 AM
Nested Door Family w/ Adjustable 3D Swing Angle
Tue, Jul 31, 2007 at 5:34:20 PM
Adjustable angle door family
Thu, May 14, 2009 at 2:30:09 PM
problem with a door family
Wed, Oct 27, 2010 at 1:19:38 PM
Shared Parameter Over Constrained Planes
Thu, May 18, 2017 at 2:13:21 PM
Page generation time: 3.8977
