25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> section marks
50 Posts No Rating |
i thought i had a short cut around having to draw up a section in drafting view, so i exported the revit section view into autocad and reimported it back into drafting view where i was able to draft the rest of section.
now i'm transfering it onto a sheet and realise that the section marks in the plans don't update to reflect the section and sheet no automatically.
is there anyway to edit the section marks manually?
thx for suggestions
You can create or edit the section mark family under the annotations folder of the revit library. Once you have done this you can change your seciton marks in your project under setting menu, under tags.
HTH
However doing this will not make it auto update just give you the ability to easily change it...
this is one of the disadvantages of using drafting views. you always much better off cutting a real section of something using then detailing over the top if need be rather than creating a 2D. This way you will retain links between details/sections etc.
HTH.
Section marks appearing on plans |
Thu, Dec 6, 2012 at 4:26:26 AM
How to make section marks smaller? |
Wed, May 9, 2007 at 4:47:08 PM
Section marks w/ SIM |
Thu, Oct 8, 2015 at 8:03:54 AM
13
Section Marks in Revit |
Wed, Feb 4, 2009 at 10:29:54 AM
Linked Views - seeing section and elevation marks R2015 |
Wed, Jul 29, 2015 at 4:53:32 PM
