Forums >> Revit Building >> Technical Support >> Is there a way to query a linked model's element?
Fri, Nov 14, 2008 at 8:45:18 PM | Is there a way to query a linked model's element?
infiltrate
Is there a way to query a linked model's element?  I am trying to identify the object by hovering the mouse + TAB on the linked architectural model, but the status bar would only tell me "RVT Links : Linked Revit Model : filename.rvt : 1 : location <Not Shared>"  It would not list more information by hitting TAB.  I want to be able to identify the objects in the linked model, such as wall type, door type, window type, and etc.Thanks
Mon, Jan 30, 2012 at 7:58:01 AM | Is there a way to query a linked model's element?
Lochnesska
Lochnesska Avatar
When you click on the DWG import, on the right in the menu there is a symbol like Layers in AutoCAD with a blue "i" called "request" (I think, don't using the english version - this layout is in Revit 2011). You click on that and then select the line or text you want to know on which layer they are. Nevertheless you'll never be able to identify them directly as revit families.
Nessie
Revit 2013
Mon, Jan 30, 2012 at 7:56:22 AM
Query regarding Linked Structural revit model
Mon, Apr 8, 2013 at 7:23:44 AM
Can't select the linked model
Mon, Aug 4, 2014 at 1:06:26 PM
Levels in linked files
Tue, May 24, 2016 at 9:40:38 AM
linked revit model disappears when I edit a floor or do an 'in place' model
Mon, Dec 17, 2012 at 8:01:15 PM
Page generation time: 0.7125
