Forums >> Revit Building >> Technical Support >> Change color of hatch?
Mon, May 16, 2005 at 2:17:14 PM | Change color of hatch?
Hmeadq
How do I set a material pattern to a color other then black? I want to set brick to be grey so it does not print so dark. Line weight one i sto dark. If I cannot do that how do I set a line weight to be less then .003"? It tells me I cannot go under this which does not make sence as the line weights are listed to 4 decimal places. Thanks
Tue, May 17, 2005 at 12:55:46 AM | RE: Change color of hatch?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You easiliy change the colour of the hatch pattern. In the material settings for cut pattern and surface pattern there is a colour choice below each pattern list. Simply set the appropriate colour... HTH.
Tue, May 24, 2005 at 8:26:54 AM | RE: Change color of hatch?
Hmeadq
But when I change it to grey it still prints as black...
Tue, May 24, 2005 at 6:10:43 PM | RE: Change color of hatch?
Xane
Did You plot in "gray's" od "black and white" in print window
2011 change material color [ 1 2 ]
Sat, Aug 31, 2013 at 8:46:22 AM
16
Hatch Question
Fri, Jan 9, 2015 at 10:31:30 AM
Can I change Structural member hatch scale, rotation??
Thu, Jan 26, 2012 at 6:18:18 AM
Material Color Change not Rendering (...but Old one does)
Thu, Mar 6, 2008 at 8:38:56 AM
PRINTING COLOR HATCH TO BLACK
Tue, Aug 16, 2011 at 1:59:52 PM
Page generation time: 1.0517
