12 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Dimension font changes when exported to Autocadd
19 Posts No Rating |
We are working with Revit 2009 and exporting to Autocadd 2007. The dimension font is ARchitxt in Revit; however Autocadd turns it into "Standard" text. All other texts, tags etc remain ARchitxt. I export with "no overrides" to keep the text "bylayer and bycolor" Please, no debate on why we use ARchitxt. It's a legacy. Thanks in advance, JSA
----------------------------------- john a |
Sounds like you will have to open your autocad files and change it back.
Can we set the dwg default text to archtxt as the standard text?
Revit and Autocad use two different types of font. Revit = True Type Font (architxt.tff) Autocad = Shape Font (architxt.shx) You'll probably notice Revit does not export text quite to the right scale either.
Edited on: Tue, Dec 23, 2008 at 6:15:49 PM
Dimension |
Tue, Apr 15, 2008 at 3:30:03 PM
Listening dimension display too small |
Sun, Jan 31, 2010 at 6:43:41 AM
Dimension String Question |
Wed, Feb 27, 2013 at 12:17:25 PM
Font issue? |
Tue, Feb 13, 2007 at 3:11:45 PM
Why I cant change Dimension fonts? |
Thu, Aug 10, 2017 at 11:51:39 AM
