Forums >> Revit Building >> Technical Support >> Can I lock a component detal to an element in the model?
Fri, Nov 14, 2008 at 12:26:51 PM | Can I lock a component detal to an element in the model?
DaveF
HiI'm using R'09I have a section looking vertical circular columns in elevation.They’re an extruded solid, I think.These columns are grouped in a subcategory within a family (Not sure if that makes any difference) I've placed the Pipe Break component over it to trim its height.  I want to lock to the column so that if I move the column the component goes with it?Is this possible? I’ve tried Pin. I’ve tried Dims but there appears to be nothing to put the dim onto (because it circular?)Hope you can helpCheersDave F.
Fri, Nov 14, 2008 at 3:05:59 PM | Can I lock a component detal to an element in the model?
Have you tried the align & lock tool?
Nest Generic Annotation in Detail Component
Wed, Mar 17, 2010 at 7:18:22 PM
Model in place component
Wed, Oct 11, 2017 at 11:46:05 AM
Lock a Revit model down / Read Only for issue to Builder
Wed, Jan 18, 2017 at 9:38:47 AM
Keeping an Element Keynote from changing?
Mon, Apr 15, 2013 at 12:14:43 PM
"Lock/Pin" Linked Architectural Model
Fri, Feb 11, 2011 at 10:13:52 AM
Page generation time: 2.6637
