Forums >> Revit Systems >> Technical Support >> Section view problem
Fri, Nov 14, 2008 at 10:10:50 AM | Section view problem
Wneuok
Working in Revit MEP 2009, I inserted the architectural model then cut a section. Then I inserted a structural model and the structural model does not show up in the section cut. However when I cut a new section they both show up and are lined up, in plan view the structural and architectural are lined up as well. Any Ideas would be appreciated?
Revit Architecture 2012 - Section shows view from behind cut line
Thu, Jan 10, 2013 at 12:38:20 PM
Section markers disappear in plan when cropping the section view.
Tue, Nov 27, 2007 at 3:33:58 PM
Section box in Section??
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section View with missing objects at certain height!
Tue, Mar 10, 2009 at 10:41:04 PM
Section line disappears from plan when section view is placed on same sheet
Thu, Sep 4, 2014 at 7:46:20 AM
Page generation time: 1.0478
