Forums >> Revit Building >> Technical Support >> plot files in revit
Mon, May 16, 2005 at 2:02:37 PM | plot files in revit
yoiyoi
could some one help with a step-by step approach to setting up a plot file in revit thanks
Mon, May 16, 2005 at 4:11:55 PM | RE: plot files in revit
arnosandoval
5 Stars: 3 Votes
When you print your sheets or views, you select your printer, and set your view up for printing as you would normally. Then click on print to file, you will get a window to show were the file will be saved. The default for Revit is a .prn file, you can change it to PLT. After that you are ready to go. HTH
PRN plot files
Sat, Apr 9, 2005 at 1:40:49 AM
raster image will not plot
Thu, Sep 24, 2009 at 8:43:42 AM
Plot Files
Thu, Oct 12, 2006 at 2:57:31 PM
Plot Preview in PDF
Wed, Feb 22, 2012 at 11:28:24 AM
Plot log
Thu, Feb 5, 2015 at 8:06:04 AM
Page generation time: 2.6229
