16 Users Online (14 Members):
Forums >> Revit Building >> Tips & Tricks >> Radius wall that leans
8 Posts No Rating |
Is there a way to make a radius wall that leans out 3 degrees. This is my first project in Revit and trying to get this to work is driving me up the walls. Currently using Revit Arch 2009. I've attached a jpg of what I'm shooting for, the "red" wall is what I'm trying to create. Thanks
If you can't stand behind the troops, stand in front!
Semper Fi |
Hi, Will this do? If you can make a mass of any shape, then you can create walls, floors & roof of most shapes.
8 Posts No Rating |
Mhans That's what I'm looking for. I couldn't figure out how to get the shape to rotate the 3 degrees, I used a triangle mass for the angled walls on the side, just couldn't do it for the curved.
Semper Fi |
Hi, Go to modeling, pick create and assign category as wall. Do a solid sweep (see attached). You can also a massing with a solid sweep and use wall by face option to have the desired wall.
how do you make a Wall with uneven thickness that leans slightly? |
Wed, Feb 8, 2012 at 8:28:23 AM
wall cleanup radius |
Thu, Aug 9, 2007 at 4:56:14 PM
Radius window jambs |
Fri, Jul 6, 2007 at 8:55:13 PM
How do you trim to a radius rather than a 90 degree corner? |
Tue, Sep 16, 2008 at 8:54:38 AM
11
Duct Elbows - Radius to Big |
Mon, Nov 15, 2010 at 3:50:20 PM
