Forums >> Revit Building >> Technical Support >> Shape handle
Thu, Nov 13, 2008 at 3:11:02 PM | Shape handle
cketros
Hi all, when I open the revit library family call w-wide flange column.rfa, I notice when I click on beam in plan view and their are a few blue triangles and it said "extrusion shape hadle"
Is it possible to create that shape handle when we create custum family?
Sat, Nov 22, 2008 at 1:33:44 PM | Shape handle
4 Stars: 205 Votes
Hi, when you create a Family you create also, Ref. planes, dimensions and parameters, so you attach your model to those ref. plans and you can control the family based in the parameters you create, so, you don't need the "Blue triangles"...
Sat, Nov 22, 2008 at 3:09:32 PM | Shape handle
If you use a reference plane that has a instance based parameter locating it and your geometry is locked to that plane, the blue grips will show up when you place the family.  Type based parameters will not do this.
Thu, Feb 19, 2009 at 6:32:48 AM | Shape handle
beyondthewall
4 Stars: 3 Votes
thanks for that tip.....
in the door family i was working on, when i make the dimension an 'instance parameter' relative to a fixed edge theres no problem but when i make it relative to another ref plane which is not pinned it shows the shape handle
thanks again !
Walls without upper shape handles
Thu, Sep 13, 2007 at 12:31:35 PM
Creating Wall Openings that show shape handles
Fri, Nov 8, 2013 at 1:11:20 PM
Help with a duct family -trying to prevent resizing by dragging or limiting drag
Fri, Dec 10, 2010 at 10:23:31 AM
Flooring Tile setting out
Tue, Jun 18, 2013 at 3:18:48 AM
difference between shape handle and editing profile?
Fri, Jun 18, 2010 at 9:00:57 AM
Page generation time: 0.8992
