Forums >> Revit Building >> Technical Support >> Drop Down Issue
Thu, Nov 13, 2008 at 1:38:16 PM | Drop Down Issue
ihenry
Basically when loaded into the project and under element properties.  There should be a drop two drop downs under construction (Door Type and Insert Type).  I want to be able to clean it up a bit because once you click on the drop down.  All types are in both drop downs.  Many thanks in advance!!  Also I am currently using Revit 09
Drop Down List in Family
Mon, Mar 19, 2018 at 4:12:18 PM
how to create a drop cap step?
Sat, Jan 30, 2010 at 4:33:00 PM
rise and drop dimension
Fri, Jun 19, 2009 at 2:30:16 PM
Revit Automatic Text Drop-Down
Thu, Nov 6, 2014 at 5:03:12 PM
Revit 2014 no Detail Section drop down to create details
Mon, Mar 10, 2014 at 7:42:59 AM
Page generation time: 0.2091
