Forums >> General Discussion >> Revit Project Management >> Cut planes
Thu, Nov 13, 2008 at 1:31:38 PM | Cut planes
Duckitech
Can individual wall or any object for that matter have its own cutplane in a given view or is based only on the views cut plane. Thanks for the help.
Thu, Nov 13, 2008 at 2:49:44 PM | Cut planes
mhans
3 Stars: 10 Votes
Hi, Not sure what you mean. Cut plane is always parallel to the view and all object that passes through this plane are cut at the same level. if you are thinking of a jagged cut plane like a section cut on plan, then you have to do some 'tweaking'.
Motto: "No Post left behind"
Thu, Nov 13, 2008 at 4:49:35 PM | Cut planes
Wneuok
I am not sure this is what you mean but you can do a plan region around a certain object such as a floor drain or window without changing the level's view range.
Mon, Nov 24, 2008 at 12:18:50 PM | Cut planes
Duckitech
Thank you for the help
Cut Planes for CMU Bearing Wall Systems
Thu, Jun 4, 2009 at 6:08:28 PM
make elevation cut line show from diffrent planes
Thu, Jul 9, 2009 at 2:10:05 PM
Shadows & Cut Planes
Wed, Jun 15, 2011 at 12:24:13 AM
Listing the Abilities of Reference Planes
Sun, Sep 9, 2012 at 9:24:07 PM
Windows & cut planes
Fri, Aug 10, 2007 at 3:24:30 PM
Page generation time: 0.2458
