Forums >> Revit Building >> Technical Support >> LINKING DRAWING INTO MOST RECENT TEMPLATE
Thu, Nov 13, 2008 at 12:14:12 PM | LINKING DRAWING INTO MOST RECENT TEMPLATE
rquist
RA 2008
 Have reactivated a drawing that's about 12 month old.  My template has progressed quite a bit since we stopped working on the drawing in question.
 I opened up a new project to activate a drawing that has the most recent template in it.
Deleted all content
used "import/link" to pull in the reactivated revit file.
thought it was unusual that I could select a few individual items like roofs, while in the same view I could also select the entire project.  Actually did delete the entire project on purpose.
First time trying to update an older drawing into the most recent template.  A little confused if I'm on the right track.
Any thoughts??
 Thanks in advance.
Thu, Nov 13, 2008 at 12:22:41 PM | LINKING DRAWING INTO MOST RECENT TEMPLATE
Go the other way.... purge unused first than transfer project standards from template to project.
Thu, Nov 13, 2008 at 2:50:18 PM | LINKING DRAWING INTO MOST RECENT TEMPLATE
rquist
THANKS
I NOTICED THAT THE DETAILS FROM TEMPLATE DRAWING DID NOT TRANSFER.  I HAD ROOF PITCH SYMBOLS AND A LOT OF STANDARD NOTES SAVED AS DETAIL GROUPS.
IS THAT NORMAL?  GENERALLY ANYTHING ELSE I SHOULD CONSIDER WHEN TRANSFERRING STANDARDS?
AS A MATTER OF NOTATING YOUR DRAWINGS, DO YOU ALSO STORE NOTES AND SYMBOLS AS DETAIL GROUPS?
Thu, Nov 13, 2008 at 3:10:23 PM | LINKING DRAWING INTO MOST RECENT TEMPLATE
rquist
DOORS AND WINDOWS ALSO DIDN'T TRANSFER???
Fri, Nov 14, 2008 at 6:08:45 AM | LINKING DRAWING INTO MOST RECENT TEMPLATE
Details are no problem.  Just File/Insert from file/Views and pick all of the views to transfer.
You can also cut & paste other missing items.
Edited on: Fri, Nov 14, 2008 at 6:09:25 AM
LOGO in drawing template
Fri, Dec 1, 2006 at 10:38:45 AM
Linking ADT imports
Tue, Apr 24, 2007 at 3:20:40 PM
Linking autocad drawing
Fri, Aug 4, 2006 at 5:57:52 AM
Recent Files
Mon, Jul 14, 2008 at 2:31:00 PM
Update my template
Fri, Mar 24, 2006 at 8:36:45 AM
Page generation time: 0.4364
