27 Users Online (25 Members):
Forums >> Revit Systems >> Technical Support >> graphic error
12 Posts No Rating |
I am having a problem with revit displaying hidden line and solid w/ line 3d views and was wondering if anyone else has had the same problem. Occasionally in the 3d view the majority of the solid objects will suddenly become transparent (or wireframe). Closing and re-opening the project usually works and everything will return to normal, however once and a while the graphic problem will stay for good. It's as though the file is suddenly corrupt. The only fix I have found for this is copying my entire project to the clipboard and pasting it into a new file. Is this the only way to fix it? How might I stop this from happening?
Already discussed in multiple threads ... if you searched using wireframe you would have found this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=12902
Very Bizzaar. Something is getting overloaded. . Just a shot in the dark. Try going to settings > options > graphics > switch between 'Using Open GL Hardware. . ' and see if that helps. . Perhaps your video display is sub-standard. Do you have graphic problems in other software than revit? . Perhaps something is getting overloaded and the graphics is loosing it's place in memory. . This could be caused by many things including video settings, service packs, software updates, drivers, OS, your revit version, concurrent applications running.
Phase Graphic Overrides |
Wed, Jul 10, 2019 at 4:01:45 PM
Graphic overrides (phasing) for 3D views |
Wed, Apr 30, 2014 at 2:25:42 PM
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
an error occurred while drawing the content of this window |
Wed, Nov 6, 2013 at 12:36:32 PM
