25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> smart elevation callouts in drafting view...
5 Posts No Rating |
Good morning, I have recently started using Revit, and this is the first project that we are using Revit. I have some drafting views in Revit of a see through fireplace set up with AutoCAD drawings linked; I also have elevations and sections that are related to the fireplace. I would like to have a 'smart' elevation marker referencing the elevation that I have placed on a plot sheet. I am able to insert section marks and reference them to the views I have created but not elevation marks. Does anyone have any suggestions or tricks that I can use other than inserting a 'dummy' elevation mark into the AutoCAD drawing? Any input would be greatly appreciated. Thank you for your time.
TrentRintoul |
Drafting Views are just that, only drafting. They are not tied to the model, therefore they cannot contain a "smart" elevation mark. You will just have to fake in a "dumb" elevation.
If you create a model view and place your drafting elements there (turn off model elements in VG), your callouts will be available.
Hi, i'm having a similar problem. I have two drafting views created. I want to reference one in the other. I can use the callout tool and section tool to reference a drafting view, but when i use the elevation tool the "reference other view" check box is grayed out. I'd really like to not use a dummy tag. Thanks,
One elevation tag / two pointer directions / one drafting view |
Wed, Dec 18, 2013 at 8:58:33 AM
Beam Callouts in an Elevation ??? |
Sat, Jan 24, 2009 at 5:37:22 PM
Spot Elevation in Drafting View |
Wed, May 20, 2009 at 2:05:17 PM
Section Callouts in Elevation |
Thu, Nov 1, 2007 at 10:54:10 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW |
Mon, Jul 29, 2013 at 4:50:17 PM
