Forums >> Revit Building >> Technical Support >> Fill Pattern Scale
Wed, Nov 12, 2008 at 4:45:01 PM | Fill Pattern Scale
zwilso2
So I have just learned that in order to have a properly scalled fill pattern you must assign a new for each and every scale.  Unless i am missing something i am very discourged by the efforts of autodesk and their revolutionary Revit.  I am currently using 2008 and have not been able to try out 2009 yet.  Does anynone know if this seamingly easy problem is fixed in the newer version?  Thanks.
Wed, Nov 12, 2008 at 7:30:12 PM | Fill Pattern Scale
mhans
3 Stars: 10 Votes
Hi,
I don't quite sure what you mean. If you need your fill pattern to scale with your view, use model pattern instead of drafting. There's hope! If not today, someday!
Motto: "No Post left behind"
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Material Fill Pattern Scale
Mon, Nov 16, 2009 at 12:53:40 PM
MEDIUM SCALE FILL COLOR AND PATTERN
Tue, Sep 11, 2012 at 7:06:12 AM
Existing Walls with Coarse Fill Pattern Revit 2008
Wed, Aug 13, 2008 at 3:28:01 PM
coarse scale fill pattern
Tue, Apr 29, 2008 at 8:48:54 PM
Page generation time: 0.7024
