28 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> Sketchup imported into Revit Error and Crash
22 Posts No Rating |
Everytime I try to import a Sketchup file into Revit, Revit tells me I have a fatal error and immediately closes my program. This even occurs when I am doing the import Sketchup tutorial in Revit! I have Revit 9, is anyone else having this problem?
Did you try to export from SK in ACIS solid to CAD, save to DWG and then import to revit in DWG??
" Did you try to export from SK in ACIS solid to CAD, save to DWG and then import to revit in DWG?? "that won't give him a sketchup file to use in Revit. are you trying to use the sketchup file that comes with the tutorial?
Yes, I've tried the Sketchup file that goes with the tutorial as well as Sketchup files I've downloaded from the 3D warehouse. I've only gotten the error thus far.
Crash crash crash |
Sun, Sep 18, 2005 at 4:34:12 AM
Sketchup imported |
Sat, Nov 13, 2010 at 1:59:38 PM
imported sketchup drawing |
Thu, Oct 8, 2009 at 9:40:37 AM
applying revit materials to imported sketchup geometry HELP!!? |
Fri, Feb 13, 2009 at 1:22:41 PM
Wall Roof Join Error with Sketchup Mass |
Wed, Jun 24, 2009 at 4:28:00 PM
