11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Adding Optional Text Field to Keynote Tag
1 Posts No Rating |
I am trying to add an instance text field to the Keynote Tag that can be turned off and on as required. I was planning on using a label, that links to "Comments" in the component, but this was not an option and there appeared to be no way to add a new parameter to the tag. Any suggestions?
Hi, did you use Yes/No parameter? check this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=6373
Sorry - Typhoon's advice works with visibility of items in regular families but you can not do this with a keynote. You can create a seperate tag that will read the comments.
Do you know that you can keynote the same element 3 times? Then you can have one of those as your comment.
Motto: "No Post left behind" |
You can use the user option and use any keynote anywhere. Just have to point to a model element first. Then move it anywhere you want. .... even out in space!
Keynote tag with text option? |
Tue, Jun 17, 2008 at 1:33:15 PM
keynote categories |
Fri, Aug 10, 2012 at 3:56:23 PM
Keynote Tag defaulting to Category Tag |
Fri, Jul 20, 2018 at 11:20:17 AM
Keynote Legend Not Showing Keynote Text |
Fri, Sep 6, 2013 at 11:40:59 AM
12
keynote tag, crooked leader |
Tue, Mar 31, 2009 at 4:44:35 PM
