31 Users Online (29 Members):
Forums >> Revit Structure >> Technical Support >> view range issues
28 Posts No Rating |
Hi all, Hopefully somene can help me out. I'm creating four different site plans to show the projects relationship to the site at each level (its a complicated site!) The problem I'm having is that when I go to set the appropriate view range for each view. It will only allow me to select the associated level for the "Top" of the view range. This option for the "Cut Plane" is grayed out and the option for the "Bottom" only offers me a very limited selection. Can anyone tell me where I'm going wrong? Thanks!
I think the issue you're having is because you're trying to use the Site plan...my suggestion would be to create another level thats called "Site 2" and then adjust all of your setting for that level. The default site level wont allow you to set a cut plane because its set to show everything without cutting so by creating a new level it should allow you all the freedom you want! Hope that helps!
Revit MEP 2012-View Range |
Fri, Apr 12, 2013 at 7:22:48 AM
View Range Issues |
Fri, Jun 10, 2011 at 7:13:30 AM
View Range for Revit Link |
Thu, Nov 12, 2015 at 7:10:18 AM
Revit 2009 help with shaft view issues |
Fri, Oct 24, 2008 at 10:41:16 AM
Plan cuts incorrectly at windows despite correct view range |
Thu, Aug 6, 2009 at 9:12:23 PM
