Forums >> Revit Building >> Technical Support >> KEY NOTE ABBREVIATION
Mon, May 16, 2005 at 3:02:44 AM | KEY NOTE ABBREVIATION
amaranth
How to I edit the properties of Key note abbreviations?
Thu, Jun 2, 2005 at 6:07:46 PM | RE: KEY NOTE ABBREVIATION
BIGMANJEE
the easiest way to edit any of the properties within a keynote is to make a new note block that schedules the parameters assigned to the keynote. use the view - new note block. then you can check out what parameters are assigned to the keynote and update etc. Either that or if you want to check it out a bit better open up the keynote family and check out the family types to see what the parameters are. add or remove what you feel necessary. hope this helps .
Key Notes Across Divisions.
Thu, Jan 27, 2011 at 10:07:01 AM
KEY NOTE
Thu, Mar 24, 2005 at 9:13:33 AM
Wall Materials & Keynotes
Wed, Mar 24, 2010 at 1:56:39 AM
key note and schedule font
Tue, Oct 26, 2010 at 11:42:31 AM
Revit 2015 - Filter Note Block Keynotes by Those Visible on a Sheet
Sun, Mar 4, 2018 at 2:08:58 PM
Page generation time: 3.2633
