25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Stone Corner and Window Trim in Masonry Wall
5 Posts No Rating |
Hey Just wondering if anyone knows the easiest way to show "keyed" stone trim around windows or coins at the corner of masonry buildings. Has anyone done this?
Like what?
I would make a generic family model of the corner keystones and then create a line-based family. Load the model of the keystone into the line based family. Then create an array of the keystone component and create a parameter for the number items in the array (call it KEYSTONE NUMBER). You will want to make a formula for the KEYSTONE NUMBER parameter. Let's say that the keystones are 2 feet apart. The forumula will then be KEYSTONE NUMBE = Length/2'. When you load this family into your project, you will be able to draw a line up the corner of the building and the detail will repeat automatically.
0 Posts No Rating |
There are specific stuff for this to use and ther geometry should also be perfect, otherwise a small .cm in excess or ommited matters a lot.
"works for http://caldwells.com/ as door evaluator" |
Stone wall covers door and window trim? |
Thu, Jan 3, 2008 at 8:50:32 AM
Arched Window in Masonry Wall |
Mon, Mar 4, 2013 at 5:28:03 AM
Arched window with stone arch above it? How to do it? |
Wed, Apr 13, 2005 at 2:22:57 PM
Wall Sweep only cuts out window not trim |
Mon, Aug 18, 2014 at 10:34:16 PM
Anyone? Why does stone render wierd here. Same wall on each side of corner |
Mon, Nov 17, 2008 at 9:52:12 AM
