Forums >> Revit Structure >> Technical Support >> Murox structural wall system
Tue, Nov 11, 2008 at 9:13:44 AM | Murox structural wall system
Murox
Murox Avatar
Hello,
 I have a problem concerning ou special structural wall system. The beam at the head of the "panel" is perfect in the familly but when I import it into a project and I change the height values "Hauteur à gauche & Hauteur à droite" in the element proprieties the beam don't connect correctly to the C columns.
 Tank you for your replies !!!!!!!!!!!!
 ***Note : If you want to test it into a project, this is a Generic model familly to apply on a wall.
Edited on: Wed, Nov 12, 2008 at 3:14:30 PM
Carl Veillette
Nothing is impossible ...
Sun, Nov 16, 2008 at 3:26:42 PM | Murox structural wall system
Murox
Murox Avatar
Forget about that I found the solution ....
Carl Veillette
Sun, Nov 16, 2008 at 3:25:56 PM
How to tag a structural beam system?
Mon, Feb 11, 2013 at 4:04:43 PM
structural beam system visibility
Fri, Jun 27, 2008 at 12:24:51 PM
sloping structural beam system - having difficulty in drawing
Thu, Dec 30, 2021 at 10:33:02 AM
structural walls copied from arch
Fri, Aug 21, 2009 at 6:49:55 AM
Page generation time: 2.6582
