Forums >> Revit Building >> Technical Support >> linking from acad
Sat, May 14, 2005 at 7:11:11 PM | linking from acad
yoiyoi
i realise that when i use the link option to import a drawing from acad to revit the explode options (both full and partial) explode are greyed out. is that normal? if so then how do i edit the drawings? thx
Sun, May 15, 2005 at 12:43:42 PM | RE: linking from acad
Scott Davis
3.5 Stars: 3 Votes
You edit a linked drawing in AutoCAD. If you want to edit it in Revit, you import the file (no link) and then explode it in Revit. Now you can edit it in Revit.
Fatal Error when linking/importing ACAD files
Fri, Aug 15, 2008 at 12:43:27 PM
Issue with linking ACAD file
Fri, May 21, 2010 at 1:05:43 PM
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
Importing a cad file
Wed, Feb 16, 2011 at 1:49:57 PM
Exported file to ACAD has problems with custom PATTERNS [made in acad]
Mon, Jun 23, 2008 at 3:21:32 PM
Page generation time: 0.0923
