Forums >> Revit Structure >> Technical Support >> How can you get lines to trim with opening cut in double tee?
Mon, Nov 10, 2008 at 11:40:30 AM | How can you get lines to trim with opening cut in double tee?
cstrip
With the attached double tee family, the lines display how I want them to in plan view.  This family is different from the revit DT family by not showing extra hidden lines at the stems.  This was done by adding model lines to the surface of the DT.  However, if I trim the double tee using the "opening by face" tool, the cut appears correct in 3D but it does not trim the lines in plan view.  Also, I do not want to do linework to every DT to get it to display correctly in plan view.  Does anyone know a way around this?
Revit 2014 - Stairs double cut line in plan
Tue, Sep 9, 2014 at 11:14:46 AM
pipe tee size
Thu, Jun 7, 2018 at 3:50:08 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Red tee
Thu, Dec 30, 2010 at 12:09:29 PM
Cutting Ends Down For Sloped Double Tees
Thu, Apr 28, 2016 at 2:49:26 AM
Page generation time: 0.5225
