Forums >> Revit Systems >> Technical Support >> Mechanical Equipment pipe connectors...
Mon, Nov 10, 2008 at 9:31:08 AM | Mechanical Equipment pipe connectors...
CKorleski
I have loaded into one of my projects some mechanical equipment with pipe connectors.  When I went to start running the piping if I high light the equipment the pipe connectors shows up 10'-0" below the equipment.  If I adjust the level that the equipment is at it moves the connector up and the equipment stays put.  If I adjust the height offset it moves both the connector and the equipment.  I have checked the family and the connector is located where it should be in the family.  Thanks.
Tue, Nov 18, 2008 at 11:21:28 AM | Mechanical Equipment pipe connectors...
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
sounds like the connector isnt associated to the correct plane...try deleteing it and replacing it to the right one lock the plane so that it moves with the component and dont forget to remap the information through the connector.
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Schedule of Mechanical / Plumbing Equipment Connectors
Wed, Feb 2, 2011 at 3:04:17 PM
pipe connectors (HELP)
Tue, Sep 22, 2009 at 9:34:52 AM
Array/group pipe connectors
Wed, Jul 14, 2010 at 4:59:44 AM
All my mechanical equipment is showing up on all the levels
Mon, Jun 11, 2018 at 2:55:08 PM
How do you change a "generic model" family into a "mechanical equipment" family?
Fri, Apr 6, 2018 at 6:18:19 PM
Page generation time: 1.1057
