Forums >> Revit Building >> Technical Support >> Problems exporting 3d Hidden Line views as image
Sun, Nov 9, 2008 at 1:24:33 AM | Problems exporting 3d Hidden Line views as image
jsneed665
I want to use the 3D views, not ones set by cameras but the generic 3d views that you work within, specifically hidden line view.  I have tried going to file>export>image but no matter what setting I try the image is extremely poor quality that you cant even see lines, just a black blob.  I tried printing to a pDF which was slightly better but still had fuzzy lines which is unacceptable for a presentation.  Any advice on best practice to do this?  It will eventually end up in photoshop to be layed out on a presentation board.  Thank You,
Jen
Sun, Nov 9, 2008 at 1:27:35 AM | Problems exporting 3d Hidden Line views as image
jsneed665
I am using Revit Architecture 2009
Sun, Nov 9, 2008 at 3:01:14 AM | Problems exporting 3d Hidden Line views as image
tim123
4 Stars: 19 Votes
In the export image dialogue box set 'Image Size' to 'Zoom to' and then you can set the Raster Image Quality, the zoom and type of image.
Exporting quality hidden line views
Fri, Jul 8, 2005 at 4:02:23 AM
Walkthrough gets 2 major problems when exporting
Mon, Apr 22, 2013 at 11:32:22 AM
Hidden line types and export to autocad
Thu, May 4, 2006 at 10:22:40 AM
Exporting views for DWG
Thu, Oct 24, 2019 at 5:52:23 PM
Hidden Line Exporting?
Mon, Jun 1, 2009 at 4:21:53 PM
Page generation time: 2.5033
