Forums >> Revit Building >> Technical Support >> Decal 2009 issue
Sat, Nov 8, 2008 at 3:58:24 PM | Decal 2009 issue
Jaybo
4 Stars: 5 Votes
I used a decal for a painting on the wall. I rendered it and worked fine and then about 10 minutes later it now doesnt work. I have tried everything i can think of to fix the problem. I reloaded the image and even tried different views . It must be a bug or something. The only thing I did was created a new decal and put it in. The new decal didnt work and then the other one didnt work. I just dont understand and i even deleted the second decal i made. Please help
Sun, Nov 9, 2008 at 3:39:00 AM | Decal 2009 issue
tim123
4 Stars: 19 Votes
I suspect that the second decals image isn't working and it is overiding the image in your first decal.  You need to create a new family to have an additional decal.
Sun, Nov 9, 2008 at 4:16:00 AM | Decal 2009 issue
Jaybo
4 Stars: 5 Votes
i did that. i even deleted both decals and did the one again. still doesnt work
Sun, Nov 9, 2008 at 4:55:29 AM | Decal 2009 issue
tim123
4 Stars: 19 Votes
Does it work in a normal 3d view (not a perspective)? Create a scope box or hide walls so that you can see it.  It may be to do with the lighting. Does the decal have a luminence level set in. Try it with 'not illuminated' set.
Sun, Nov 9, 2008 at 5:08:30 AM | Decal 2009 issue
Jaybo
4 Stars: 5 Votes
I can see the 2d line work of the decal in all views. when i render nothing shows up in  an y view i render. i even tried day. its not illuminated. I just dont know why it worked before and not now. is there any bugs in2009 with decals. I been using revit for over 3 years and i must say this seems like a bug. The only other thing that has been as strange as this problem was the when i used pantones the key oard freezes lol. That was a bug in 2009 so i was wondering if the file is stuffed or its bug.
Sun, Nov 9, 2008 at 5:11:20 AM | Decal 2009 issue
4 Stars: 205 Votes
Hi, i had the same problem a few months ago, i had a decal in a tv screen and it render fine, then a few days after it didn't render, what i did was delete the decal, import again the decal, duplicate the name and apply in 3 diferent places, 2 in the wall and the other in the tv, render and i check the decals in wall render fine but in the tv wasn't, i didn't place that decal in the screen of tv but in the frame around the screen so the render (decal) only appears in the frame, then i delete and create a similar of the others in the wall and pick in the Screen, not the frame, and adjust the image and render, Voilá, depend where are you place your decal...
I hope you understand my english...
Sun, Nov 9, 2008 at 5:19:06 AM | Decal 2009 issue
Jaybo
4 Stars: 5 Votes
it is a painting on a wall. i tried place it in 3d view and elevation. same problem Sad
Sun, Nov 9, 2008 at 5:25:40 AM | Decal 2009 issue
4 Stars: 205 Votes
And did you update your Revit to WEB UPDATE (20080915_2100)?
Sun, Nov 9, 2008 at 5:28:49 AM | Decal 2009 issue
Jaybo
4 Stars: 5 Votes
ok you have pin pointed the problem thanks. I dont under stand why it wont render of the wall but i created a new wall behind it and now its working. very strange how the wall wont work with the decal but im happy now thanks
Sun, Nov 9, 2008 at 5:29:42 AM | Decal 2009 issue
4 Stars: 205 Votes
This is what i did to check what a hell are going one in my render decal: http://screencast.com/t/YlIru1wKQN
OH, but render in a wall, it's the same thing, if uou place the decal in a wall it must render...
Edited on: Sun, Nov 9, 2008 at 5:31:39 AM
cannot see Decal and Rpc elements in new project 2009
Sun, Nov 23, 2008 at 5:17:13 AM
Decal rendering
Sun, Nov 9, 2008 at 4:02:33 AM
Revit Architecture 2013 - Decal Tool not functioning
Mon, Jan 13, 2014 at 10:18:31 PM
Revit Architecture 2009 Decal tools
Fri, Jul 25, 2008 at 8:34:10 AM
How to Remove Black Line Around Decal
Tue, Jul 12, 2016 at 7:09:10 AM
Page generation time: 1.9207
