Forums >> Revit Structure >> Technical Support >> Section Cut
Fri, Nov 7, 2008 at 1:17:32 PM | Section Cut
fcfcadd
Does anyone have the standard Section Cut that comes with Revit modified to allow for the Reference Text to be placed in any of the four corners? I want to be able to select which corner I want the text to show up in. If not can someone show me how to do that.
47730_section.TIF
Fri, Nov 7, 2008 at 2:52:24 PM | Section Cut
I do not think you can do that.  You can turn off the sim and place your own text.
Fri, Nov 7, 2008 at 3:02:52 PM | Section Cut
fcfcadd
Thats whats been done before but when you have a ton of them on 1 sheet it would easier to just update the family type and then be able to select which ones had which part turned on. Such as TopRight, TopLeft, BotRight, and BotLeft.
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Sections cut on mulitple sheets
Fri, Jun 27, 2008 at 12:33:38 PM
Is it possible to not have the bold section cut lines
Thu, Apr 3, 2008 at 12:58:16 PM
Segmented section cut
Wed, Oct 10, 2007 at 1:19:40 PM
Animate section cut?
Sat, May 29, 2010 at 5:15:48 AM
Page generation time: 6.4740
