Forums >> Community >> Newbies >> scheduling structural props of walls or roofs
Fri, Nov 7, 2008 at 11:53:28 AM | scheduling structural props of walls or roofs
3drulez
4.5 Stars: 2 Votes
i have a query regarding the use of scheduling in revit. in architectural practice we calculate plaster surface areas or painting areas or finish areas . can that be done straightaway in revit with scheduling . i mean to use the structural properties of a wall or roof to schedule them .   because only those things can be scheduled which are parameters in revit . am i correct. but structural properties of wall or roof i e its composition are not included in its parametric properties. so how to schedule them .
i am using revit 2008. btw.
Sat, Nov 8, 2008 at 12:03:47 PM | scheduling structural props of walls or roofs
4 Stars: 205 Votes
3D, i just respond this same question in the other post you thread here...
Sat, Nov 8, 2008 at 4:47:16 AM
Openings in (Structural) Walls Scheduling as Non-Bearing Walls
Thu, Feb 21, 2008 at 5:55:28 PM
structural framing vs scheduling (volume report)
Fri, Feb 25, 2005 at 11:15:12 AM
Shading Structural Walls
Mon, Nov 21, 2011 at 11:21:46 AM
structural usage for stacked walls
Tue, Jun 30, 2015 at 6:59:56 PM
Page generation time: 0.4083
