Forums >> Revit Structure >> Technical Support >> Wall Footings and Foundation extrusions
Fri, Nov 7, 2008 at 9:42:50 AM | Wall Footings and Foundation extrusions
mreed
When you put typical wall foundations in they trim and chamfer at junctions and corners.  The problem I am having is that I made a wall foundation using the solid extrusion feature.  I did this because there are steps in my footing and I wanted the model to look right.  Well when you do this, where the foundation extrusion meets a wall foundation at a corner they do not trim.  Is there a way to make these trim and look correct.  See attached picture.
Fri, Nov 7, 2008 at 11:08:14 AM | Wall Footings and Foundation extrusions
coreed
coreed Avatar
4 Stars: 16 Votes
what was it about your foundation having steps in the footing that you thought you could only do by using extrusions. coul you post a elevation shot of the foundations.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Nov 7, 2008 at 12:08:00 PM | Wall Footings and Foundation extrusions
mreed
See attached elevation.
Fri, Nov 7, 2008 at 1:16:37 PM | Wall Footings and Foundation extrusions
coreed
coreed Avatar
4 Stars: 16 Votes
you can simply edit the profile of the foundation wall to create the stepping that you show in your elevation post. using extrusions is not needed in this case.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Nov 7, 2008 at 3:15:06 PM | Wall Footings and Foundation extrusions
mreed
I agree that you can do it that way.  I was just wondering if there was a way to do it with the extrusions so you can make the footing step (with tapered edge) look correct in the model.  I like your way because it is easier and looks good on the plan.  The way I was wanting to do it is probably not necessary because no one ever will the see the 3-D view but I thought it would look good.
Fri, Nov 7, 2008 at 4:05:54 PM | Wall Footings and Foundation extrusions
coreed
coreed Avatar
4 Stars: 16 Votes
are you refering to that sloped angle line that you show in your elevation as making the footing step with tapered edge. if so you can also create that by modifing the profile also.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Nov 7, 2008 at 4:55:40 PM | Wall Footings and Foundation extrusions
mreed
I know you can change the profile of the wall, but how can you change the profile of the foundation?
Sat, Nov 8, 2008 at 6:56:40 AM | Wall Footings and Foundation extrusions
coreed
coreed Avatar
4 Stars: 16 Votes
maybe i am not understanding something. could you post the extrusion you created?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Jun 7, 2016 at 10:38:24 PM | Wall Footings and Foundation extrusions
southpantera1984
Hey guys, I tried to create a create a family component using the wall foundation bearing footing as a template but then i realized that there is no family template because it s a system family. OK great.
So then I tried option 2 , what if a create a sweep - profile - wall-  of the ( inverted t-shape foundation ) to be attached to the base of my wall so it can be adjustable as my wall moves or extends ???... i was so thrilled this could be the end of this stressful quest but then I ran into this msg
Could not create integral wall sweep for wall instance. Sweep position is outside of its wall. Please check sweep parameters.
but Im touching the base edge as any other profiles can ... as long as Im bound to an perimeter wall edge and the profile it's not floating in the air;  should be good right ??
Does anyone know how to bypass this or get around a situation like this. Please help ...because of this I have 3 brand new gray hairs on my scalp. lol
Wed, Jun 8, 2016 at 7:55:54 AM | Wall Footings and Foundation extrusions
Does this need to be a BIM element or only for documents?
You may need to just do an in-place family - sweep - structural foundation category.
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
dashed line for foundation footings?
Thu, Feb 9, 2006 at 4:04:06 PM
Creating Existing Footings in Revit Structure
Mon, Jan 4, 2010 at 12:09:19 PM
Page generation time: 1.1111
