Forums >> Revit Building >> Technical Support >> Sheet Boundaries
Thu, Nov 6, 2008 at 6:08:12 PM | Sheet Boundaries
velvetseas
Is there a way to show a sheet's boundaries?  I'm sure there's a simple thing I just don't know how to do.  Would like to know where I can place things on my sheet before they are floating in the ether.
Thanks in advance!
Fri, Nov 7, 2008 at 4:00:40 AM | Sheet Boundaries
Dafpfy
3.5 Stars: 11 Votes
press F1
you should probebly make a titleblock to import into your sheet ( or import a standard one )
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Fri, Nov 7, 2008 at 7:25:33 AM | Sheet Boundaries
We use invisible lines on our titleblock sheets to show the printable area.  You can see them all the time but after placing a view, you can roll-over the sheet and then see the relationship of the view to the boundry.
Fri, Nov 7, 2008 at 9:35:16 AM | Sheet Boundaries
velvetseas
F1 just goes to Help...which didn't help, unfortunately.
I suppose we need to outline the page in our title block xref so that that is imported ni with the titleblock?
Fri, Nov 7, 2008 at 9:44:54 AM | Sheet Boundaries
Why are you using an import?  This should be a REVIT sheet family.  It needs to be parametric and the edge of the paper will show up all the time when you use it.
Fri, Nov 7, 2008 at 9:50:06 AM | Sheet Boundaries
velvetseas
I'll have to talk to the guys here that set it up.  Don't know why we're xreffing in our CAD titleblock.
Fri, Nov 7, 2008 at 10:16:18 AM | Sheet Boundaries
Dafpfy
3.5 Stars: 11 Votes
lol dont import a cad title block as a xref,
you can do so much more with a titelblock familie and 'project parameters'
Edited on: Fri, Nov 7, 2008 at 10:16:41 AM
peace is the path."
Mahatma Gandhi.
Fri, Nov 7, 2008 at 10:22:02 AM | Sheet Boundaries
velvetseas
I have a feeling this was a quick-needed thing before we were able to set up the Revit family for it.
Thanks for all your help, guys!
Phantom Area Boundaries
Tue, Sep 29, 2009 at 1:12:12 PM
Any way to automaticaly find room boundaries to make finishing floor?
Wed, Sep 17, 2014 at 8:13:11 AM
Room boundaries woun't properly display
Tue, May 15, 2018 at 3:08:14 AM
Room Boundaries limited?
Fri, Jan 30, 2015 at 5:19:55 PM
editing room boundaries [ 1 2 ]
Thu, Oct 5, 2017 at 7:21:19 AM
16
Page generation time: 0.2040
