19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Color Schemes
10 Posts No Rating |
Is there a way to transfer color schemes from project to project? Also is there a way to changes the value name after it is created? thanks
I don't have access to revit at the moment to check but I'd imagine you could use "transfer project standards" to copy this between projects.
Regards,
Chris.
1 Posts No Rating |
I also have this problem. We have spent some time trying to set up a nice color scheme for the office. This was for a school project. But now when working on a nursing home (with mostly different rooms, obviously!) I want to keep the colors that i know work nicely toghether, print ok etc but I want to assign new rooms to the colors. Its a lot of work to type in the RGB values and it seems rather meaningless.
area color schemes |
Fri, Jan 27, 2012 at 12:07:13 PM
Revit Spot Elevations, Rooms and Color Schemes Problem |
Mon, Jun 24, 2013 at 12:46:35 PM
Color Schemes |
Wed, Jun 3, 2015 at 3:15:18 PM
"System Color Schemes" not regular color schemes in Elevation or Section views |
Mon, Mar 22, 2010 at 6:00:00 PM
Color Schemes |
Thu, May 23, 2013 at 12:35:43 PM
