Forums >> General Discussion >> Revit Project Management >> Component Families
Thu, Nov 6, 2008 at 10:04:31 AM | Component Families
amber01aggie
General Question:
Are families imbedded into each file?
For example, if someone copy clips an component family from one project central to another project central, and then edits the family and doesn't save, but loads it into project central 2.  Where are those changes referenced to?  Will it effect the original component family in project central 1?  Is it always necessary to save AND load the family?
Fri, Nov 7, 2008 at 9:41:59 AM | Component Families
robinballew
robinballew Avatar
3 Stars: 4 Votes
Revit will never automaticaly check to see if the Families have been updated. If you open a family from the project, make changes, and load it back into the project without saving you will only update that one family in that one project. Even if you save the changes all other projects that use the "old" version will not be modified. The family exists entirely in the Revit project.
 Hope that helps..
BallewDesigns.com
Fri, Nov 7, 2008 at 10:06:21 AM | Component Families
amber01aggie
Thank you so much.  That's exactly the answer I was needing (after hours of debate in my office, and me on the loosing end!).
Adjustable length in component families
Mon, Jul 26, 2010 at 1:45:33 PM
To Annotate a component
Tue, Jun 26, 2018 at 12:10:05 PM
Text & Families / components
Tue, Dec 12, 2006 at 10:39:12 AM
Embedded detail component scale issue
Mon, Oct 15, 2007 at 10:07:15 PM
Families and hosts of families
Wed, Jul 11, 2007 at 11:42:24 AM
Page generation time: 4.1222
