11 Users Online (9 Members):
Forums >> Revit Structure >> Technical Support >> Riser profile?
16 Posts No Rating |
I would like to create a riser with a profile like the nose profile that can be selected. Attached is a image of what i would like. I can create profiles easy enough, but is there the option to have a riser profile? im not sure if it is something simple i've missed? or am i just best to draft/sketch a riser on to the stair detail and forget about it in sections etc? Any help or ideas would be great, im using 2009 Revit Structure. Thanks in advance, Dylan
Hi, see the video and give me a feedback ok? : http://screencast.com/t/yqUv5mCN
Hi Typhoon, Thanks for that, the videos are a great idea also. (i didnt have sound on my computer, so wasnt sure if there was any, but the footage was all i needed) I was thinking of doing something like that also, but was worried if i changed a floor hieght or something along those lines that it would effect the hieghts and position of the treads and that would leave the risers floating in mid air.
Edited on: Sun, Nov 9, 2008 at 4:05:30 PM
Hi, the video has sound, "I was thinking of doing something like that also, but was worried if i changed a floor hieght or something along those lines that it would effect the hieghts and position of the treads and that would leave the risers floating in mid air." - no problem because when you create the sweep you can constrain the path to the step, so they are locked to them...
ahh ok, Ill have a look at the video again with sound when i get the chance. yeah ofcoarse, was off in my own little world when i wrote that about the constraining. Thanks again for the help
Stair Riser Profile |
Fri, Jun 25, 2010 at 10:46:19 AM
Stair - Cut Profile |
Wed, Sep 14, 2011 at 1:36:18 AM
Staircase Sketching - Riser count not reducing in number |
Thu, Jul 11, 2013 at 5:40:37 AM
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN |
Fri, Sep 2, 2016 at 7:03:03 AM
riser stair problem |
Tue, Nov 6, 2018 at 7:10:17 AM
