10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Remove hidden CAD imports
Hello, Along the process of developing a Revit project,I have imported Cad underlays, and hidden them. In my visibility graphics under Imported objects, I am reminded of imported CAD files that have been hidden and still exist in my file, but I can't find them. Is there a way to easily locate what view these rogue hidden Cad files are in so I can delete them? C
Couple of things may help here... If you hid them by element ro category the "Reveal Hidden Elements" lightbulb should show them up. Select the CAD plan, then right click and choose "Select all Instances". Then delete them. You may have linked them in. In this case go to the File Menu and then to "Manage Links" where you will be able to see the links and remove them. Good Luck
You might just look in the VG of the views and turn them on there. NOTE: They may still be hidden by model elements so you may need to turn off the model in VG to find them.
Some good tips. Thanks
CAD exports showing hidden entities. |
Wed, Jun 24, 2009 at 9:00:37 AM
Adding Material to Families based on Cad Imports |
Tue, Jun 23, 2009 at 11:37:00 AM
REMOVING CAD IMPORTS IN REVIT MEP 2011 AFTER DELETING |
Thu, Sep 9, 2010 at 10:23:27 AM
Materials Wrong when Rendering Families w/ 3d CAD Imports RA2008 |
Fri, Sep 21, 2007 at 7:45:27 AM
stair sections and hidden lines |
Wed, Jul 27, 2005 at 3:02:29 AM
