Forums >> Revit Building >> Technical Support >> AutoCAD prints but Revit does not
Wed, Nov 5, 2008 at 4:22:20 PM | AutoCAD prints but Revit does not
JHectorne
RAC 2008
Hello.  We are having some trouble plotting Revit files.  When I go through the print setup dialog and select the sheet that I want to plot, everything seems fine.  No warnings of any kind are given.  Then the plotter will feed out the media and print only a few parts of the model.  We can print from AutoCAD to the same plotter without any problems.  Does anybody ideas of what could be going on with our plotter?
Thanks in advance.  Jim
"You've got to remember that we are just simple operators.  We are people of the web.  The common clay of the new millenium.  You know...Newbies."
Thu, Nov 6, 2008 at 7:22:46 AM | AutoCAD prints but Revit does not
tim123
4 Stars: 19 Votes
We had a similar issue with our OCE plotter.  Revit uses Windows drivers - you probably need to obtain new drivers from the manufacturer which can print Revit drawings.
missing walls, fixtures in pdf prints
Mon, Jul 3, 2006 at 3:41:57 PM
AUTOCAD PLOT STYLES
Mon, Feb 11, 2008 at 11:09:46 AM
crop option for printing in sheet
Tue, Apr 1, 2008 at 7:34:48 AM
Inserted Image prints upside down
Sun, Nov 13, 2016 at 9:42:45 PM
Line weight of text from linked AutoCAD files
Fri, Sep 23, 2011 at 3:12:39 PM
Page generation time: 1.4139
