Forums >> Revit Building >> Technical Support >> Mitering cornice family
Wed, Nov 5, 2008 at 2:11:07 PM | Mitering cornice family
CarriageStone
3 Stars: 2 Votes
Need some help.  I've created a wall based family of a two member cornice that works pretty well except that I dont;t know how to make it miter and return at a 90degree angle to the house.  Also, I'm not able to run it around an outside corner.  Otherwise, I like it just fine.  Any ideas?
I've asked my contacts at my Autodesk reseller and the suggested having it nested in part of a wall assembly.  That won't work though, as I am creating this for exterior use and need to be able to adjust it to meet the fascia.  If the rafters need to rest on a 2' kneewall, building the cornice as suggested by the reseller won't work.  It needs to have the flexibility to move up and down.
Hopefully the attachment will show the family I created.
Thanks all!
Wed, Nov 5, 2008 at 4:03:49 PM | Mitering cornice family
4 Stars: 205 Votes
Hi, see the video and give a feedback...: http://screencast.com/t/e2fJwU9nS
Wed, Nov 5, 2008 at 6:58:39 PM | Mitering cornice family
CarriageStone
3 Stars: 2 Votes
Typhoon,
Thanks so much for posting the video.  I really can't thank you enough for taking the time to put that together.  Once I get my kids in bed, I'll spend some time with it and let you know how it works.
If I wanted to create some custom sweep profiles, what would you recommend to be the best method?
Don
Wed, Nov 5, 2008 at 7:22:51 PM | Mitering cornice family
robinballew
robinballew Avatar
3 Stars: 4 Votes
I would make a profile family and then make a wall sweep. Wall sweep is hosted by the wall but not part of the wall. Let me know if you need more detail.
BallewDesigns.com
Thu, Nov 6, 2008 at 3:38:45 AM | Mitering cornice family
4 Stars: 205 Votes
Hi, like Robin said, create your "profiles (2D)" in "Metric/Imperial Profile" and save them all in one folder "Profiles" "Metric/Imperial Library",in the Profile-family if you go to Settings-Family Category you can change the family category, take a look on this, then you have the two choises i post in video yesterday...
Thu, Nov 6, 2008 at 2:52:25 PM | Mitering cornice family
CarriageStone
3 Stars: 2 Votes
Typhoon & Robin,
Thanks a ton for your help.  After following your suggestions, I was able to easily create the cornice.  See attached.  It's a typical multi-member cornice used here in Richmond.  I also included a 1x8 fascia so that I could tie to the roof easily.
I hope you like it.
Thanks.
Thu, Nov 6, 2008 at 3:28:28 PM | Mitering cornice family
4 Stars: 205 Votes
You forgot to attach...
Thu, Nov 6, 2008 at 3:54:46 PM | Mitering cornice family
CarriageStone
3 Stars: 2 Votes
Connectivity problems today.
Try it now.
Thu, Nov 6, 2008 at 4:48:17 PM | Mitering cornice family
4 Stars: 205 Votes
Nice, one more type for my profiles, thanks...
Fri, Nov 7, 2008 at 2:32:12 PM | Mitering cornice family
CarriageStone
3 Stars: 2 Votes
Typhoon,
Try this one.  I think you'll like it.  You can adjust it away from the wall and miter it at 90 dgrees to return it.  It's a nice, simple way to create a finished porch entablature (Tuscan Order for a 10" Column).
Enjoy.
Fri, Nov 7, 2008 at 3:00:52 PM | Mitering cornice family
#11
4 Stars: 205 Votes
Thanks CARRIAGE, i think you must put here this family in "Upload content" to the others....
In place family cornice
Tue, Jul 15, 2008 at 7:14:05 AM
Cornice on exterior wall disappears when I place window 2' above it?!
Mon, Nov 28, 2011 at 2:22:07 PM
how to add cornice to the roof ?
Tue, Aug 22, 2017 at 3:17:59 AM
Advice - Wall Cornice
Fri, Feb 3, 2012 at 12:05:51 PM
Mitering curtain wall panels
Wed, Dec 26, 2007 at 9:11:55 AM
Page generation time: 3.1848
