Forums >> Revit Structure >> Technical Support >> How to create masonry or concrete lintels and display them correctly?
Wed, Nov 5, 2008 at 10:53:04 AM | How to create masonry or concrete lintels and display them correctly?
FourStar
I have created a generic wall based family specific for lintels.  It works fine in the model but I can't get it to display right.  Ussually for a masonry lintel for example the hatch will break at the opening.  I can't set the cut plane down low at the opening because it doesn't show the framing at the deck bearing level.  Any clues as to how I can show everything I need to or different settings I can use?
Fri, Apr 9, 2010 at 3:42:59 PM | How to create masonry or concrete lintels and display them correctly?
ecriswell7
Did you ever figure this out?
masonry lintels
Thu, Jun 12, 2008 at 12:58:13 PM
masonry walls?
Tue, Jun 22, 2010 at 5:35:51 PM
Lintels in Revit Structure
Mon, Nov 5, 2007 at 10:31:29 AM
concrete wall and masonry wall to have different lineweights
Thu, Jan 6, 2011 at 12:39:04 PM
LINTELS
Tue, Sep 11, 2007 at 12:52:11 PM
Page generation time: 2.9371
