Forums >> Community >> Newbies >> footing queries
Tue, Nov 4, 2008 at 10:23:06 PM | footing queries
asit
hi all,
i am working on revit structure 2009 and i am facing this strange problem while working with isolated foundations.
as example : i have created a footing F1-1500x1500x500 and i have placed it at several places as required. now i need to create F2-1500x1650x500 for other columns. the moment i create and place F2 in the building, from the foundation schedule the type marks F1 & F2 vanishes and numbers of footings also vanishes. it considers F1 & F2 as same as the first dimension 1500 is common for both.this happens always when the width of two foundations are identical.
am i going wrong somewhere ...please help me out
thanks
asit
Sat, Nov 8, 2008 at 1:27:36 PM | footing queries
tim123
4 Stars: 19 Votes
Edit the family and duplicate it. giving it a new name. An instance property apllies to only that one, but a type property will apply to all of those unless you create a new one.
Sun, Nov 9, 2008 at 12:51:00 AM | footing queries
asit
thanks tim...
i got my answer the next day.....
actually problem was with sorting the footing by width in ascending order i.e. in the schedule of foundation
when i changed the sorting order from 'by width' to 'by type mark' , the problem solved ...my mistake only... Winking
thanks again
asit
footing queries
Mon, Nov 17, 2008 at 1:08:42 AM
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Foundation Top of Footing (when Level is something other than 0'-0")
Fri, Jan 29, 2016 at 1:40:13 PM
Top of Isolated Column Footing forced to snap to bottom of column
Mon, Jan 13, 2014 at 7:41:43 PM
Wall profile footing issure
Fri, Oct 3, 2014 at 7:06:49 AM
Page generation time: 0.0267
