Forums >> Revit Building >> Technical Support >> 64 bit version
Tue, Nov 4, 2008 at 8:33:33 PM | 64 bit version
trhymans
Just got a new computer w/ Vista 64 and installed Revit 2009 from the original disk that says either 32 or 64 bit.  I did not find a choice on installing the 64 bit version and cannot find a place where it tells me if the 64 bit version was installed.  Is there a way to comfirm that the 64 bit version is installed.  I installed the 64 bit version of Acad but I can't find any way to confirm that one either.  I assume that one is 64 bit since I installed it from the disk that said 64 bit version.
Wed, Nov 5, 2008 at 11:02:33 AM | 64 bit version
trhymans
There is only one disk for Revit which appears to have both the 32 bit and the 64 bit versions so I assume it checks on installation and installs the proper version but I was still wondering if there is a way to confirm that the 64 bit version has indeed been installed
Wed, Nov 5, 2008 at 11:26:19 AM | 64 bit version
coreed
coreed Avatar
4 Stars: 16 Votes
the 64-bit version is only available as a download to subscription users at the moment. it is the autocad-architecture that has two disk, which comes with the Revit. i think?
if the 64 bit version is installed it will be in the Program Files folder and not the Program Files (x86) folder
under about Revit the build should be 20080915_2100(x64)
Edited on: Wed, Nov 5, 2008 at 11:35:22 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
windows XP Professional x 64 bit
Wed, Sep 27, 2006 at 12:39:51 PM
64bit demo
Sun, Jan 11, 2009 at 6:19:29 PM
revit latest version cannot be save to a lower version
Wed, Apr 27, 2011 at 10:00:25 AM
Thinking about switching to 64 bit Revit. Got questions.
Mon, Jun 8, 2009 at 2:48:16 PM
Page generation time: 0.1799
