32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> Mouse Scrolling
10 Posts No Rating |
I am haveing a problem with my scrolling using the mouse wheel, instead of getting the screen to gradullay zoom in and out, it goes way in or way out to were i cannot see the plan.
I have bought a new mouse and installed with the new drivers and set the wheel setting s, but i am still having the same problem, when i switch back to ADT i do not have this problem.
Am suggestions or solutions out there?
I am curretnly using ver 7, have asked to be upgraded to 8, but until then I need help.
Thanks
5 Posts No Rating |
I have seen this problem with some Microsoft mice. What you will have to do is, go to control panel and then the mouse section. On the wheel tab, there is a "troubleshooter" button. Click on this and follow the steps. The troubleshooter will ask you to select in which running program the mouse is not working correctly. It will fix it up for you. Remember to finish the troubleshooter completely. Dont just close out of it or the repair will not take place permenantly.
Brett
3D rotate view with mouse |
Wed, Dec 2, 2009 at 2:33:54 AM
Anything other than a mouse! |
Wed, Nov 26, 2008 at 9:42:58 AM
13
Mouse Speed |
Tue, Jul 19, 2011 at 4:48:43 PM
MOUSE PROBLEM |
Mon, Nov 23, 2009 at 11:08:32 AM
Logitech Revolution Mouse |
Fri, Feb 2, 2007 at 12:24:16 PM
