23 Users Online (21 Members):
Forums >> Revit Structure >> Technical Support >> Creating slab edge...
28 Posts No Rating |
Is there a way to create a different size of slab edge? I'd like for my 4" floor slab to thickened down to the top of my footing when they come together at the perimeter of the building. So the slab can bear on the footing. Currently Revit Structure has 24"x12"x12", but mine needs to be specific to each diffent footing that the slab is bearing on. Is there a way to having a thickened slab edge that can be edited in a section view? I'd like to be able to just pull the points of the slab edge to make it wider or narrower. Sorry if my question is confusing, but I'm used to working with AutoCad, and I'm just now doing my first job with Revit. Thanks
Hi, see the video: http://screencast.com/t/1jKh2s2gG
I couldn't get that address to work typhoon. I'd like to watch it.
The video it's Ok, if you have any problem, in the bottom of the JING page you will see this "Please click here if you are having trouble viewing this content." pick on that "click here" in the page and you can see how can you solve the problem to watch the video....
Thanks Typhoon, I actually found another thread on here that give me a nice work around. So I've fixed my slab edges so they look correct in my building sections. But I'll watch the video also. Thanks
Also see this other video to complete the other: http://screencast.com/t/mhZRx7Sx7DZ
"Could not create Slab Edge" |
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab |
Thu, Jul 14, 2011 at 11:04:56 AM
Revit 2010 Slab Edge Trouble |
Mon, Feb 15, 2010 at 8:54:39 AM
Create Void as Slab Edge |
Sun, Oct 2, 2016 at 11:39:37 PM
Thickened slab edge |
Sat, Jan 28, 2012 at 4:57:49 AM
